Wheels won't turn!!! '90 B18A1 into '91 CRX SI
We've dropped the B18 into the CRX but as we went to push it out of the garage we found the front wheels won't turn. The tranny and axles are good (shift linkage not in yet), i'm more than a little confused but it was getting dark by this time so we kinda gave up for the time being. Tomorrow we're going to check it out and see if it's something stupid we missed, anybody ever have a similar experience or have some idea of what we should look for??
Re: Wheels won't turn!!! '90 B18A1 into '91 CRX SI (pfcfutrell)
Did you remove the metal spacer rings on the hubs and the dust ring on the axle? That will keep you from being able to turn the wheels once they are tightened down. Also, is it in gear?
[Modified by Blown90hatcH, 8:28 AM 9/2/2002]
If the steering wheel turns without effort and does not have any return-to-center tendency, then how about checking to see if the steering tie rods are connected to the knuckles?
If there is resistance, then there is blockage somewhere. Find the hinderance and remove it. Shouldn't be anything real hardcore. At worst the axles could be the cause.
New User
Re: Wheels won't turn!!! '90 B18A1 into '91 CRX SI (Blown90hatcH)
What are you talking about?
Re: Wheels won't turn!!! '90 B18A1 into '91 CRX SI (slowerthanu)
[Modified by Blown90hatcH, 9:35 PM 9/3/2002]
dude you said you dont have your shuft linkage hooked up...right?. well how about hooking it up and ptting it in NUETRAL.
