ob2ENGINE to 95si
Old Sep 5, 2002 | 08:18 AM
yaya's Avatar
Default ob2ENGINE to 95si
i did search for this for about 15 minutes....couldnt find anything
quick q
if i use a 96 b18c (obd2) in my 95si (obd1) with a chipped p28, do i just scrap the b18 wiring harness and wire the whole engine to the si harness??
***how do i use an ob2 engine to work with an obd1 ecu?
Old Sep 5, 2002 | 10:19 AM
yaya's Avatar
Default Re: ob2ENGINE to 95si (BrianP)
ttt some1, i know this has an easy answer
Old Sep 5, 2002 | 11:12 AM
g's integ's Avatar
change the plugs on the dist and vtec solenoid. Also wire up the secondaries on the geezer mani.
or trade your dist and solenoid for obd2 one...
Old Sep 5, 2002 | 02:55 PM
yaya's Avatar
Default Re: ob2ENGINE to 95si (g's hybrid)
wire up my 2ndaries?
with a p28 they still need to be wired?
uhhh trade my OBD2 distributor and soleniod for an OBD1? is that waht you meant?
the engine is OBD2 and the car/ecu is OBD1
Old Sep 5, 2002 | 10:12 PM
94cxhybrid-T's Avatar
New User
i did this with a 2000 si motor in a 94 hatch. i cut off the plugs from the old distributor and soldered them on to the new distributor. As far as the secondaries they are useless without the p72. As far as the vtec solenoid i had to add the wire to the ecu but you dont since your car is wired for vtec. You may have to change the plug as previously stated.HTH
Mike
Old Sep 5, 2002 | 11:16 PM
Civicboy's Avatar
From what I have been told if you run a chipped P28 you do not need to add any wires. the chipped ECU is programed to run everything the way it sits. That is what i have been told at least
Old Sep 6, 2002 | 08:24 AM
g's integ's Avatar
opps for bout the p28, duh me
Old Sep 6, 2002 | 12:30 PM
Civic DX 4dr's Avatar
I recently did a 96 gsr swap into a 92 cx hatch. I just kept the obd2 gsr harness attached to the motor and plugged it up to the car. Everything worked fine. The obd1 ecu wont be looking for any of the obd2 sensors. We also used a chipped p28. There's no need to wire up the secondary butterflies since there wont be anything activating them anyways. Hope that helps.
[Modified by Civic DX 4dr, 9:32 PM 9/6/2002]
Old Sep 6, 2002 | 01:15 PM
Civicboy's Avatar
Default Re: ob2ENGINE to 95si (Civic DX 4dr)
Can't wait to do mine.
mdrouillard1983
Mar 20, 2018 10:32 PM
baldeagle432
Sep 18, 2009 09:53 PM
sol-oto
Sep 1, 2009 12:43 PM
Patrickchampagne2006
Mar 21, 2007 02:35 PM
screen_name
Apr 22, 2006 06:56 PM
