Opinions on my next project.
i plan to build a b18c1 n/a.
my plan:
1st stage:
b18c1 with 85-86mm
11.5-12.0 CR JE
Crower rods
JG Pro series Head (already have)
Skunk 2 manifold (c1 head)
stock gsr cams
lighter pulleys all around (p/s, crank etc)
rc 310cc injectors
aem fuel rail and pressure regulator
jdm sir II ecu
2nd stage:
100-150 shot Direct Port NOS system
fuel: 103 unleaded.
i am open to suggestions on how i can improve on my set up.
my plan:
1st stage:
b18c1 with 85-86mm
11.5-12.0 CR JE
Crower rods
stock gsr cams
rc 310cc injectors
jdm sir II ecu
2nd stage:
fuel: 103 unleaded.
Re: Opinions on my next project. (BoostedbyFastrax)
running that high compression and then putting nitrous on it is a sure fire way to a new engine, the two dont agree with each other, if you want to put that much nitrous through it you will be better off lowering the compression of the motor and strenthing the block just as if you were going turbo, but you first stage looks good to me
carbonkid
12
12-06-2012 01:52 PM
Eyes Only
09-15-2003 05:55 PM
