sohc vtec ECU ????
Old Sep 2, 2002 | 07:09 PM
fasterthenmost's Avatar
Default sohc vtec ECU ????
Hey guys I just got a SOHC Vtec for my 92 CX so it will not be stock soon. The swap looks pretty straight forward. I just dont have a P28 ecu and was wondering if i can use my stock CX ecu i think it P06. Will it work so I can drive it, I know I wont have vtec but I just want to do the swap cause i got some free time but need to be able to drive it atleast. don't want to do the swap and cannot drive it because I don't got an ECU. Someone please get back to me?????
thanks so much in advance
Old Sep 2, 2002 | 07:48 PM
DX187VTEC's Avatar
Default Re: sohc vtec ECU ???? (fasterthenmost)
i would imagine u could but u would not have vtec....unless u ran a activator switch id think....im new 2 the game also.... but i would most definate go with a p28....i have a 98 hatch and in the process of mini me swap....i have a p2p but im thinkin of goin back 2 the obd1 (p28).....
Old Sep 2, 2002 | 07:49 PM
Redline130's Avatar
It will run like a plug, but at least you will be able to drive it. I was in the same boat when I swapped a Z6 into my friends dx hatch. I had to use the dx ecu until I could find a p28. The car ran ok, just no vtec and it seemed like it was running a little lean.
Old Sep 2, 2002 | 09:13 PM
Default Re: sohc vtec ECU ???? (cyber13)
thanks so much guys I will do the swap cause now I have the time available and I will just have to use my CX ECU till I get a good deal on my P28 or P72. I will let everyone know how it goes and how it runs?? Still happy I am going Z6 though!!! Thanks again for all your help.
Old Sep 2, 2002 | 09:59 PM
ransack's Avatar
Default Re: sohc vtec ECU ???? (DX187VTEC)
like he said, it should werk with the ECU, but no vtec. Let us know how it goes
Old Sep 3, 2002 | 11:00 AM
eg6ajk's Avatar
P05 = USDM CX ecu (for 70hp 1.5l motor with single wire 02)
P06 = DX ecu (for 102hp 1.5l motor running 4 wire 02)
either will work, the fuel and ignition maps are weak but then again since when was a d16z6 a performance motor?
but yes it will get you around
Old Sep 3, 2002 | 11:02 AM
khang77642's Avatar
Default Re: sohc vtec ECU ???? (eg6ajk)
hey guys, if you are interested in a p28. I have one for sale. Hit me up and make offer. Thanks
darkmarc
Aug 20, 2004 09:45 AM
fasterthenmost
Sep 3, 2002 06:21 AM
memphiss13
Feb 21, 2002 08:57 AM
