anyone have pics of the back of their motor?
...as the topic says. I'm looking for pics of the back of any b-series motor. I need reference for routing the wiring harness.
Thanks
Thanks
Re: anyone have pics of the back of their motor? (jg)
http://www.geocities.com/b20bvtecpre...lock.12.08.jpg
cut and paste the link to work - sorry
back of a dirty B16A,
basically plug the alternator wires in, then hte oil pressure sensor and knock sensor, then teh intake manifold its and make sure you use hte crades as they sit on hte manifold support piece...
hth,
t..
[Modified by tinkerbell, 3:56 PM 9/4/2002]
[Modified by tinkerbell, 3:58 PM 9/4/2002]
hth,
t..
Re: anyone have pics of the back of their motor? (Rspool)
Here are a few pics from my GS-R swap. The last one will probably look drastically different from yours though, as I have removed the stock black box, rerouted coolant hoses, installed a freeze plug and tapped previously blocked off points. Either way, HTH.
Re: anyone have pics of the back of their motor? (netnutshatch)
is this swap finished netnutshatch?
which catch can did you use? any problems with oil level in the can???
TIA,
t..
TIA,
t..
thanks guys. That's all I needed. I couldn't remember if the harness was routed above or below the intake mani. support bracket on the ITR motors.
fullblown
02-13-2005 08:37 PM
