o2 sensor problem
Old Sep 4, 2002 | 11:41 AM
boot machine 5000's Avatar
Default o2 sensor problem
the '99 si harness used for my gsr swap only has one o2 sensor plug. i think the previous owner took it off or something. well is there any way that i can tap into the one o2 sensor to hook up the other. trying to do this, to get rid of the check light for now because i cant afford to switch over to obd-1. thanks.
Old Sep 4, 2002 | 12:26 PM
Trey's Avatar
25 Year Member
Default Re: o2 sensor problem (Alvin)
The secondary O2 goes through the floor board (behind the cup holder) and plugs into the interior harness (green plug at the ECU).
You will see a rubber plug near the cat on the body. The O2 goes in there. You then have to extend the 4 wires to teh correct pins at the ECU.
What year ecu and car do you have? (it makes a difference)
Old Sep 4, 2002 | 12:35 PM
1 speedstar's Avatar
Default Re: o2 sensor problem (Trey)
im doing the same thing except my car is a 96 with the cx harness. is it the same for mine? i thought just extending my second o2 sensor to reach the plug on my cx harness would work? tia
Old Sep 4, 2002 | 03:31 PM
'00 civic dx, '00 b18c, '99 si ecu and harness
do u have a diagram of the exact location where the wires go into the ecu
[Modified by Alvin, 12:36 AM 9/5/2002]
Old Sep 5, 2002 | 06:08 PM
where do u the o2 wires to on the ecu? the diagram for 96-98 is different
t-del28
14
Feb 28, 2013 06:43 PM
da59block
Nov 16, 2011 11:25 AM
-=ZAK=-
May 3, 2009 04:43 PM
Lynx
Oct 15, 2003 03:10 AM
