Whats the best CRVTEC setup??
Ok I just got a b20b.....what do I need or should i say whats best for me to do to build a crvtec for a crx hf.... and kinda in a low budget too.... whats the best head do u guys suggest.
[Modified by jodesi9, 9:13 AM 9/15/2002]
More information is needed, what are your goals? N/A or turbo? what transmission will you be using? Will there be any crank driven accessories? etc. etc. etc.
if I was you I wouldn't go b20/vtec yet.. I'd go straight b20.. get a good header so u can re use it when u do the vtec head swap..get some cheap o Ls intake manifold..run it like that .. save up even more then BUILD the beast
hahah bob
I'll just get some piston for the b20, You dont need aftermarket rods because stock rods are fine and strong. Just remember to get new parts.
best = http://www.importbuilders.com
cheapest = Do It Yourself and don't do much either
pick one... sounds like you need a little more reading under your belt.
Cheap, Reliable or fast.
choose 2. you can only have 2.
low budget+crvtec=broken motor.
[Modified by KAMiN, 2:26 AM 9/16/2002]
i just put my built crvtec into my rex this past weekend... https://honda-tech.com/zerothread?id...723173#2723173
if i had to it all over again, i would do this:
-straight b20 nonvtec (obviously)
-y1 tran w/ quaife lsd
-good header
-aem cai
-100 shot wet direct port NOS
-custom 2.5 exhaust with low restriction muffler
a crvtec setup adds up quick. i have about $5500 in mine as of now and i got some really good deals on some of the big priced items.
[Modified by Jeff C, 10:39 AM 9/18/2002]
-good header
-aem cai
This is a guy I know's setup. He ran a 13.8@106mph on street tires.
b20vtec -pr3/ef8, y1w/lsd
*every purchasable suspension part
*every power making bolt on
*hondata-4 stand alone fuel management ]
crzymine03
11
Mar 11, 2017 10:36 AM
xtegb16x
Apr 29, 2006 11:06 AM
MugenSi00
Feb 19, 2002 10:08 PM
