What do I hook a chain to to hoist the engine out?
On the front, I'm going to use the power steering bolt holes....what else should I use?
I looked for a while, and couldn't see any good place to hook to?
help me
help me
Re: What do I hook a chain to to hoist the engine out? (hot_EG)
there's usually a tab on the front where the tranny mates with the motor. on the back, you could screw a bolt into an empty hole, or use the alternator bracket.
Re: What do I hook a chain to to hoist the engine out? (CivicNewbie)
the big starter bolt (easiest access) and there is a hole on the back of the head (drivers side) that a 14mm bolt will go into
thats what i used.
thats what i used.
Re: What do I hook a chain to to hoist the engine out? (Kamin)
In my helms for my 94 gsr it shows 2 attatchments for the hoist, one on drivers side rear block, and one on trans side. Where do you get these
Re: What do I hook a chain to to hoist the engine out? (TurboTeG4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTeG4 »</TD></TR><TR><TD CLASS="quote">In my helms for my 94 gsr it shows 2 attatchments for the hoist, one on drivers side rear block, and one on trans side. Where do you get these</TD></TR></TABLE>
I raised my car @ 3ft off the ground and put it on h.d. jack stands and just dropped the engine/tranny out of the bottom of the engine bay using a large transmission jack(one used for big rigs) It has saftey chains attached to the main part of the jack hold the engine and tranny in place keep the it from shifting and falling. This process takes about an hour or two if I have no problems. I have an engine hoist but I only use it for RWD cars. Now that I'm into hondas it makes a nice coat rack.
hook it to the plug wires ,thats what i do...ha ha sorry guys i couldn't resist.but in all honesty.i go on the alternator bracket,and then on the tranny in the back.but it also helps to use a tilter it makes things alot easier.
The Internet Tough Guy
13
05-17-2006 07:18 PM
