F22B Head swap for SOHC VTEC
Help
Is swapping the head of an F22B (non VTEC) for a SOHC VTEC head feasible. Do I need a new ECU, wiring harness. I can get a head for $NZ500.
Would this then be viable for turbo later?
Re: F22B Head swap for SOHC VTEC (Rydaddy)
What your smokin Rydaddy?
I have a SOHC Non VTEC F22B engine in my RHD Japanese 4WD Odyssey. There is also SOHC VTEC versions using the same F22B block. I was wondering what was involved with doing a head swap from a wiring and ECU perspective.
My other option is to swap the engine for an H22A DOHC VTEC. However I want to retain the existing 4WD Auto transmission.
Uhh.......?? Dont think you can put a D series head on an F series block....
OneSloEk9
08-18-2010 01:32 PM
