B18C5 in a 3G teg
Old Sep 14, 2002 | 10:38 AM
keebler65's Avatar
Default B18C5 in a 3G teg
if i was to start with say an LS or something and wanted to swap in a B18C5, is it a direct bolt in? what would need to be added/modified as far as:
vtec
iab
axles
mounts
other wiring
etc
thanks! btw i did a search but didnt find much. i guess B18C5's are expensive
Old Sep 14, 2002 | 10:47 AM
YumVTEC's Avatar
Default Re: B18C5 in a 3G teg (keebler65)
vtec
iab
axles
mounts
other wiring
etc
The motor is a direct bolt in, and you can use any 3g integra axles. ITR axles would be best. All 3g integra mounts are the same except the ITR mounts are a little stiffer. There is no IAB on a b18c5, only on h22a's and b18c1's. IAB = dual stage intake manifold, b18c5 = single stage.
As far as wiring is concerned, you'd have to add knock and vtec wires I believe to the LS intermediate harness for the ITR harness to plug in and work properly with the ITR ECU.
Old Sep 14, 2002 | 10:53 AM
keebler65's Avatar
Default Re: B18C5 in a 3G teg (YumVTEC)
sweet i was hoping it would be as simple as that
amoebiasis
Apr 23, 2014 08:13 PM
b16a1eg6
Feb 28, 2006 02:29 AM
.Noah Fecks
Aug 23, 2003 12:54 AM
Train
Apr 12, 2003 05:05 AM
mycvc8u2
Jan 5, 2003 12:18 AM
