swap question ls/vtec
I already have a manual transmission. Im pretty sure that I can get a jdm b16a longblock from an automatic and use it with my manual tranny right? Would i need to do anything? Also, can I get a vtec head off a automatic b16a and use it for ls/vtec?
Im pretty sure its yes but want to make sure. Thanks.
Yes, auto b16 head will work for LS/VTEC. You might want to upgrade the cams, valve springs, and retainers though.
[Modified by b19coupe, 8:21 AM 9/7/2002]
The LS harness can be used, but vtec will have to be wired, oil pressure switch, solenoid, knock sensor. For like $20-$30 more you can get a dohc vtec harness with everything needed.
(i am sure you already knew this though)
SteaveO2
May 21, 2009 06:38 AM
