B20 Crank Pulley Question, Take a look at this Pic, please...
Old 09-09-2002, 05:14 PM
b20guy's Avatar
Default B20 Crank Pulley Question, Take a look at this Pic, please...
Hope someone understands what I mean. Do I just go buy a woodruff key and shave it down so its flush with the pulley?
Old 09-09-2002, 05:32 PM
tinkerbell's Avatar
Default Re: B20 Crank Pulley Question, Take a look at this Pic, please... (b20guy)
i recall my B20 pulley had a key.
but i dunno how to help you?!?!
i would have to check when i got home what the deal is...
i will do and post back (in 7hrs) if another answer is not forthcoming...
t..
Old 09-09-2002, 05:44 PM
b20guy's Avatar
Default Re: B20 Crank Pulley Question, Take a look at this Pic, please... (tinkerbell)
so it was like the pic on the left or right?
[Modified by b20guy, 8:45 PM 9/9/2002]
Old 09-09-2002, 05:47 PM
tinkerbell's Avatar
hmmm, ummm, ill take the pic on the left thanks!
but ill have to check tonight for you (7hrs...)
t..
PS do both your pulleys have rubber dampeners?
Old 09-09-2002, 05:49 PM
b20guy's Avatar
yes all 3 pulleys, and the rubber damper sandwiched inside
Old 09-09-2002, 05:54 PM
tinkerbell's Avatar
hmmm, so the LS pulley has a dampner too.
i was planning on using a B16A pulley - but it doesnt have a dampner...
i dont know whether this will be OK what do you think?
t..
PS ill check tonight for you on the B20 pulley
Old 09-09-2002, 06:31 PM
b20guy's Avatar
I wouldn't chance it.
Old 09-09-2002, 07:32 PM
boomslang's Avatar
1999 GSR on the left. 1997 B20 on the right. They both use a woodruff key.
Old 09-09-2002, 07:41 PM
tinkerbell's Avatar
Default Re: B20 Crank Pulley Question, Take a look at this Pic, please... (Inlinefour)
looks like i wont have to check at home
thats it. they both need a key...
t..
Old 09-10-2002, 04:12 AM
SuperCivic's Avatar
i'm using the b16a pulley so i wouln't have to get new belts...
no probs yet
Old 09-10-2002, 05:25 AM
b20guy's Avatar
Default Re: B20 Crank Pulley Question, Take a look at this Pic, please... (SuperCivic)
Ok, got it. There are two keys required according to acuraautomotiveparts.net. The dealer was wrong I guess. Thanks everyone.
[Modified by b20guy, 8:29 AM 9/10/2002]
Old 09-10-2002, 07:08 AM
DevinW's Avatar
Is there a reason you are using the LS pulley B20Guy? I was going to check mine tonight for you, but I guess u got the answer...
Old 09-10-2002, 03:44 PM
b20guy's Avatar
Default Re: B20 Crank Pulley Question, Take a look at this Pic, please... (DevinW)
A pulley didn't come with my longblock. That's the only reason, really. I found a 2001 LS one for $25 (and it came with 3 belts) 17k miles. Ebay heh heh...
Anyway, I bought a key today, and everything was good.
Old 09-19-2002, 05:29 PM
jaysonx's Avatar
Also, a B20 pully will overdrive your alternator at higher RPM's. Its good to go with a smaller one off another B series engine.
Old 09-19-2002, 06:18 PM
Westrock2000's Avatar
Default Re: B20 Crank Pulley Question, Take a look at this Pic, please... (jaysonx)
Ya thats good to know, the B20B pulley seemed larger than an LS one, so I was either gonna get a aluminum LS one or just use the one of my LS, that way I can still get LS sized belts.
Old 09-19-2002, 06:19 PM
Default Re: B20 Crank Pulley Question, Take a look at this Pic, please... (Westrock2000)
Then again won't a smaller pulley make the belt turn faster, in other words the B20 pulley would make everything turn slower.
Old 09-19-2002, 06:33 PM
b20guy's Avatar
I think basically, the ls pulley will turn my dx a/c compressor and alternator closer to the speeds it used to turning
vgsr
12-16-2013 04:38 AM
civicjason
02-28-2010 06:37 PM
JJtegfan14
05-26-2009 01:27 PM
Danal976
08-03-2008 05:39 PM
Quick Reply: B20 Crank Pulley Question, Take a look at this Pic, please...
