Having problems with my gsr swap in my 91 crx si
I can't get the wire harness in the gsr injectors should i use the 89-91 B16a injectors if anyone had done this swap i need help with wiring like which wires to cut off my gsr harness and put it in the stock one and does all the stock harness hook up or are some left out thanks
[Modified by XzzYzzX, 11:34 PM 9/7/2002]
Re: Having problems with my gsr swap in my 91 crx si (XzzYzzX)
i assume youre using your stock si harness? Also, if youre not converting your car to obd1, youre gonna need obd0 injectors among other parts...which ecu are you running?
shortA25
01-21-2011 12:35 PM
90Rexx
09-15-2010 10:47 AM
itRfan1
10-21-2006 08:42 PM
