How to Keep an automatic transmission in a swap ?
Old Sep 15, 2002 | 07:22 AM
ROBZPCS's Avatar
Default How to Keep an automatic transmission in a swap ?
I have an 88 OEM SEDAN DX, the engine i would like to put in is a 90 CRX Si BLOCK with a 96 1.6L SOHC V-TEC HEAD; my mechanic believes that I may need a different throttle body, (SOMETHING ABOUT THE KICK-DOWN) also he isnt possitive on which ECU would work best with this application. he is considering AN ACCORD THROTTLE BODY & AN automatic INTEGRA ECU... ANY insight on this would be greatly appreciated. Thanx
Old Sep 15, 2002 | 12:58 PM
SiZ's Avatar
SiZ
Default Re: How to Keep an automatic transmission in a swap ? (ROBZPCS)
You could probably do that.. Use the TB from the SOHC VTEC though I would think.. For the ECU you'd probably be best to use the D16A6 ECU with some sort of VTEC controller like a VAFC to activate the VTEC.. I don't think a teg ECU would be a good idea..
When my Civic was auto I used to have a DOHC ZC swap.. It was pretty quick.
Check it out:
http://www.geocities.com/jdmzc
[Modified by SiZ, 1:59 PM 9/15/2002]
ash-ta
Jul 9, 2013 10:13 PM
the king.
12
Jan 24, 2007 06:19 PM
stemiched
11
Nov 20, 2006 08:09 PM
civicdragger818
12
Dec 31, 2003 08:32 PM
tr4il
Nov 25, 2001 11:38 AM
