2000 jdm b18c/1998jdm b18c
I have a 98 Ek hatch and am about to get a swap. Is there a difference in wiring harnesses in a 2000 and a 1998 jdm itr b18c. I just don't wanna run into big problems. I know i have to modify the harness, i'm cool with that, but i don't know if a 2000 itr ecu will fit my 98 ek harness ecu plugs.
[Modified by sleeprhatch, 2:39 PM 9/13/2002]
Re: 2000 jdm b18c/1998jdm b18c (sleeprhatch)
The motors are the same, you will need to use your stock civic harness and modify it. Use the plugs from the itr harness and all jdm itr ecus will fit in your 98 harness. CTR ecus are different, along with the usdm itr ecus 2000+. Weird, huh?
Re: 2000 jdm b18c/1998jdm b18c (Jackson)
Location: Toronto, Canada currently residing in ATL, GA, USA
You can use the engine wire harness that comes with the motor, I know because that's what I've been doing. It does reach (Close) but it reaches.
ek_bape
11
08-06-2018 09:43 AM
96CivicBoostCoupe
02-09-2007 11:18 AM
ricky05
03-08-2006 02:43 PM
