CEL 23, knock sensor. How do I fix it?
Old Sep 7, 2002 | 08:45 PM
Thagreybomber's Avatar
Default CEL 23, knock sensor. How do I fix it?
I've gotten a CEL for knock sensor. How do I fix it? I've checked the plug to see if it's in all the way, good. I've checked the connection on the ecu, good. The wire from the plug to the ecu is good. What else should I look at to remedy this problem?
Sometimes it'll come on, sometimes it doesn't. That has happened only a few times though. It usually comes on while normal driving, at about 3500-4000rpm on the freeway.
HELP! TIA
Old Sep 8, 2002 | 06:46 PM
R_yd's Avatar
Default Re: CEL 23, knock sensor. How do I fix it? (Thagreybomber)
try replacing the sensor w/ a good one.
Old Sep 8, 2002 | 09:48 PM
BoOsTeD_eK's Avatar
Default Re: CEL 23, knock sensor. How do I fix it? (Rspool)
could the sensor actually be working...and you are experiencing knock?
Old Sep 8, 2002 | 10:50 PM
Default Re: CEL 23, knock sensor. How do I fix it? (BoOsTeD_eK)
I don't believe I'm experiencing knock...then again I don't know what I'm supposed to be listening/looking for. If I do have to replace it, is it an easy/cheap fix?
Thanks folks
Old Sep 10, 2002 | 09:53 AM
311's Avatar
311
i think they are about $100 from http://www.hondaautomotiveparts.com , but it is generally a pain in the **** to change because of its location on the back of the block. Good luck.
Old Sep 10, 2002 | 10:51 AM
SuperCivic's Avatar
sounds like popping/pinging coming from the motor. are you running 93 octane gas?
Old Sep 10, 2002 | 01:29 PM
BoOsTeD_eK's Avatar
Default Re: CEL 23, knock sensor. How do I fix it? (SuperCivic)
I have an extra one lying around...$35 shipped...off a 2000 si.,
Old Sep 11, 2002 | 10:16 PM
I'm running the California 91 octane. I'll listen for those sounds tomorrow. Thanks folks!
garyc17
Dec 1, 2007 12:48 AM
petarr
Mar 4, 2006 10:37 AM
Sean Juan
Feb 13, 2006 04:31 PM
Thagreybomber
Sep 9, 2002 07:17 AM
