H22 wiring help...
Old Sep 15, 2002 | 02:39 PM
Jonathan_ED3's Avatar
Default H22 wiring help...
I want to go ahead and finish the wiring between the ECU harness and the Strut tower harnesses...
The pins I have empty are the following:
A: 7,9,10,14,15,18
B: 10, 12, 13, 14
D: 8,12,16, 17, 19
I know I need to add D12.....
BTW, this is in a '92 CX that's been through a couple of swaps...so some things that I should need to wire are already there.
So far I think that's all I need to add. Can anybody confirm this for me?
Old Sep 15, 2002 | 02:51 PM
Default Re: H22 wiring help... (hot_EG)
Does anybody happen to have the Hasport wiring chart?
i keep going to the page, and it says 'for complete wiring chart, see bottom'...and I go down, but nothing's there.
Anybody have it?
Old Sep 15, 2002 | 03:35 PM
Mikey3000's Avatar
i don't understand. what do you have wired so far? the only things you need to add are knock, vtec oil pressure, and vtec solenoid.
Old Sep 15, 2002 | 03:55 PM
Default Re: H22 wiring help... (Salvatore Leone)
well i don't personally have anything wired up..the car's been through a few swaps though...so it's already got a few of the VTEC things wired up...
Vtec oil pressure is already done along with Vtec solenoid
Knock sensor is already done...
and I want to add the EGR too.
All I need to still add is EGR, right?
Old Sep 15, 2002 | 08:29 PM
i've been told I can leave off EGR...
So I don't need to do anymore wiring from the ECU to the strut tower, yes?
Old Sep 16, 2002 | 08:59 AM
heiyu's Avatar
i wired mine directly from motor to ecu though a hole in the firewall behind the battery. If you check out my site alll the info is there. just look at the charts. Also be sure to save pictures to your harddrive. im run out a band width every month and it goes down. Also if anyone have JG camgears avoid them. My car was running like **** and i lined them up with stock ones and they where missmarked. i couldnt belive it. all the time i spent rechecking my work and it was the camgears. now my car really goes.
Old Sep 16, 2002 | 10:05 AM
Mikey3000's Avatar
yeah don't even worry about running the egr. actually, if u want it to pass emissions you better hook it up. i don't know how to though. mine isn't hooked up.
Old Sep 16, 2002 | 10:16 AM
yeah...if it's emissions related I'm going to have to know how to hook it up...grrrrr
Anybody know how?
FlyingDaggers
Nov 5, 2007 04:26 AM
Jakester9500
Jan 4, 2007 12:48 PM
grncivic98
Apr 10, 2005 12:22 PM
hondaswaph22
Aug 25, 2003 07:47 PM
2ndGenREX
Jun 5, 2003 06:59 PM
