Si to ZC, Can you swap fuel rail and plug wires?
Old 09-09-2002, 01:46 PM
ScottEK's Avatar
Default Si to ZC, Can you swap fuel rail and plug wires?
The ZC I got has a majorly j4x0red fuel rail, one of the injectors is missing the rubber rings that holds it in, another doesn't have the bottom plastic piece which I hope is not in the fuel rail. Can I just swap my fuel rail off my Si? Also are the plug wires interchangable?
Old 09-09-2002, 06:24 PM
ScottEK's Avatar
Default Re: Si to ZC, Can you swap fuel rail and plug wires? (beta13)
Someone has to know this, they look the exact same... I know you can use the Si throttle body would this mean for any reason you can use the Si Fuel Rail?
Old 09-10-2002, 12:07 PM
ScottEK's Avatar
bump... sorry still looking for some confirmation
Old 09-10-2002, 06:18 PM
EightOhOne's Avatar
It should work
Old 09-10-2002, 06:43 PM
zcivic91's Avatar
Default Re: Si to ZC, Can you swap fuel rail and plug wires? (EightOhOne)
u can use ur si fuel rail and washers..
also whiel its out pull the injectors and spray them with nonchloronated brake cleaner for a cleaning..
loki17
04-10-2004 04:28 PM
pelotudo
15
02-08-2003 08:32 AM
Hondasaurs
11-07-2001 02:56 AM
Quick Reply: Si to ZC, Can you swap fuel rail and plug wires?
