need wiring help for sohc vtec
Old 09-08-2002, 09:53 PM
sohcvteccrx's Avatar
Default need wiring help for sohc vtec
need any wiring info on sohc vtec into 88 crx hf. i know the computer is going to have to be swapped but don't know what computer is best to use.
Old 09-08-2002, 11:43 PM
ef civic's Avatar
Default Re: need wiring help for sohc vtec (sohcvteccrx)
you could go alot of ways you can convert to obd1 or you could just leave it obd-0 and use a 88-91 si ecu, distrib,injectors and a rpm switch or chip the si ecu but if i was you i would convert to obd1 you have alot more options that way and it would be faster then the obd 0 option
[Modified by ef civic, 12:43 AM 9/9/2002]
[Modified by ef civic, 12:44 AM 9/9/2002]
Old 09-09-2002, 05:33 PM
Default Re: need wiring help for sohc vtec (ef civic)
ef civic, do you have know what i need to convert my crx to obd-1.
thats what i want to do i know i need a p28 ecu do by chance know
the wiring. thank you for your help,
sohcvteccrx
Old 09-12-2002, 08:38 PM
vtecrx's Avatar
use a p28 ecu, obd0 to obd1 adapter harness from blown90hatch, z6 injectors and distro. that is the best way to do it. I am running my z6 in my crx with a pm6/vafc setup and I wish I had gone obd1.
Andy
srt4pilot
05-10-2009 05:10 PM
kuso1
07-03-2006 03:40 PM
robichaux
04-07-2004 11:25 PM
Aphrodavid
05-11-2003 04:41 PM
Sirex
02-21-2003 09:32 PM
Quick Reply: need wiring help for sohc vtec
