Math 101 (Cont.d): Compression Ratio of ITR Stock Head on b16a Block with CTR Pistons?
Can anybody give a number for the compression ratio for stock ITR head on to a stock b16a block with CTR pistons?
Thanks, all
Thanks, all
Re: Math 101 (Cont.d): Compression Ratio of ITR Stock Head on b16a Block with CTR Pistons? (Ruby Civ
If you are using all OEM parts for this, the compression ratio will be the same as the CTR motor, as the heads from the ITR, CTR and all B16s are 42.7 cc's.
hmmm, i do remember it being said that combustion chamber was same (42.6/7) and that CR was ~10.86 dep on gasket choice and all else stock
