Does a GSR oilpan hang lower than a b20/LS oilpan?
The reason I am asking is because I want to get a block girdle for my B20, and I need a GSR oilpan....I will be using a B16 OEM exhaust manifold and I am wondering if it will clear the gsr oilpan? Thanks for your help...
Guest
Posts: n/a
Re: Does a GSR oilpan hang lower than a b20/LS oilpan? (DevinW)
it will clear it.. but it will be very close.. and the header might actually touch the oilpan. The reason it does is not because of the oil pan itself.. but because the b16a has a shorter deck height than other b-series motor. In simple terms, a b16a motor is shorter.
If you put a b16a header on a stock ls motor, you most likely will get a slight clearance issue.
Re: Does a GSR oilpan hang lower than a b20/LS oilpan? (mingchi96)
Hmmm...so a GSR or Type R OEM exhaust manifold would fix the problem?
slowdaintegra
06-16-2009 02:44 PM
