type r block, sir1 head, cable tranny, EF civic???
i have a friend who is buying a type R block from me and he wants to put it in his EF civic and im wondering what all will need to be done, will everything bolt up ?
will the existing wiring harness work being that the block is obd2 and everything else is obd0?
what will we need?
thanks
what will we need?
thanks
Re: type r block, sir1 head, cable tranny, EF civic??? (egcivicturbo)
mounting kit, unless you want to weld (hasport, hcp, or place)
a lot of people don't recommend place. hcp and hasport seem to be the good ones.
wiring harness might be required, but i only have seen obd2 to obd1, and obd1 to obd0. ask blown90hatch, he has some harness for sale
you will probably need a y1 tranny considering its a cable tranny he'll need. shift linkage and axles too. i'm thinking the 90-93 integra axles will work, but i could be wrong. modified shift linkage. there are probably other things you would have to consider, but i'm not an expert so hopefully someone else can help you.
ttt for you.
[Modified by l0p3z, 8:28 PM 9/15/2002]
ttt for you.
LSej1
02-20-2008 05:00 PM
D3U1LT
09-20-2004 05:52 PM
