TPS Sensor
Old Sep 15, 2002 | 11:32 AM
HypertecSi's Avatar
Default TPS Sensor
Does anybody know the stock setting for TPS on a 2000 Si
Old Sep 15, 2002 | 12:37 PM
AzG35's Avatar
Default Re: TPS Sensor (HypertecSi)
I believe its .5 volts closed, and 4.7v fully opened. +/- .1v
Old Sep 15, 2002 | 02:08 PM
Kataku2K3's Avatar
Default Re: TPS Sensor (AzSi22)
yup that's good you want 0.5vdc with the throttle closed and at WOT 4.5-5.0vdc
Old Sep 15, 2002 | 02:47 PM
HypertecSi's Avatar
Default Re: TPS Sensor (JDMspecEG6)
Thanks now I can set it to the right voltage.. It was at .454 and didn't idle right.
Old Sep 18, 2002 | 05:33 AM
zcivic91's Avatar
umm...i was testing my tps yesterday cuz im having troulbe wit my zex kkt..
i came up with 4.6v CLOSED throttle and .58v open throttle..
is my tps in backwards or sumtin??
if u have the plug off the tps points down and to the passneger side..correct?
Old Sep 24, 2002 | 05:20 PM
Kataku2K3's Avatar
Default Re: TPS Sensor (zcivic91)
Are you putting it on a motor with DPI (dual point injection) I figured out that my friends CRX had that when i dropped a B16 in his car...
Old Sep 25, 2002 | 01:45 AM
sparkz's Avatar
.45-.5v is accpetable for closed and nomore then 4.5v at full
cmgibby
Jul 24, 2008 12:22 PM
nutball72
Nov 11, 2006 07:14 PM
TheSav
Apr 10, 2006 11:23 PM
Achenar
14
Jul 15, 2005 03:27 PM
GSRcivicGSR
Dec 20, 2004 04:29 AM
