Speedometer Tech Needed
Old Sep 15, 2002 | 08:36 AM
Sleeper Sii's Avatar
Default Speedometer Tech Needed
I'm finally done with the swap of a JDM B16 into my 91 civic si.
However, the speedometer sender from the transmission appears to be electrical.
My speedometer is a manual cable driven.
Any way I can get a working speedometer out of this?
[Modified by Sleeper Sii, 12:37 PM 9/15/2002]
Old Sep 15, 2002 | 11:57 AM
VTECVillain's Avatar
Default Re: Speedometer Tech Needed (Sleeper Sii)
I had a friend that had the same problem with the B16 in his 90 Si hatch. I think he unscrewed the plug mount and took the one of his stock Si transimssion and mounted it on. Don't quote me on this though, let me check with him and I'll get back to you. I do know that the electrical unit still has the same type of hole and small shaft that spins inside underneath the plug.
Old Sep 15, 2002 | 12:14 PM
Kamin's Avatar
Default Re: Speedometer Tech Needed (VTECVillain)
that should work
just take the VSS off the old transmission and put it in the new one.
Clash0901
Jan 16, 2010 01:23 PM
coot_er
May 14, 2004 01:33 PM
bardo
Mar 10, 2004 05:36 PM
90hbvtec
Dec 10, 2003 06:22 AM
b16powwer
Jul 8, 2002 10:08 PM
