jdm d15b
Old Jan 22, 2003 | 07:56 AM
citrusdrop's Avatar
Default jdm d15b
WHat is need to put on of these into an EG....which ecu and wiring harness should I use....
does anyone make internals for this motor....I was thinking of buying one only like 500 what do you think?
Old Jan 22, 2003 | 08:24 AM
ce's Avatar
ce
Default Re: jdm d15b (citrusdrop)
You would need the same as for a D16Z6 engine...Their similar except for displacement...
Old Jan 22, 2003 | 10:38 AM
eg6ajk's Avatar
i used to have it. its nothing more then d16z6 head with vx bottom end (block), power output is around the same mark as d16z6 but with 2-4lb.ft less torque.
original ECU is a JDM P08, harness use your harness and add vtec wiring if necessary.
check out my projects:
http://hyper.phluid.net/projects.html
KarbinFourteen
Sep 29, 2004 04:29 AM
dragonhaven2001
Jun 28, 2003 07:25 PM
PotatoePAPA
Mar 22, 2003 04:25 PM
