b20 vtec experts??????? Balance and polish crank????????????
hey wassup guys im askin if anyone has balance and polished their crank in a b20 block. Im askin if it does make a difference and if it helps out with the power band. Either that or if you guys have any other suggestings to do just let me know..
thanxs
thanxs
New User
Re: b20 vtec experts??????? Balance and polish crank???????????? (92TurboLS)
if you are rebuilding it i prolly would get the bottom end ballanced. everything should be close to spec but it wouldn't hurt.
jesse
jesse
thanxs
thanxs
that is dictated by cams...
if you are running big hi-rpm cams, then a micro polished or 'nitrided' or cyro treated crank will help you not break stuff...
i have not touched my crank, but when i do the rebuild with forged rods and hi-comp pistons, i will be polishing it and nitriding it, PLUS balancing the entire reciprocating assembly...
t..
Re: b20 vtec experts??????? Balance and polish crank???????????? (tinkerbell)
When I got my block built I got the whole bottom end balanced and my crankshaft polished. I decided to do this because IB was taking part my bottom end anyways. If you are rebuilding your block then it will be worth the $100 to do it. The only way the crank will produce power is if its a different crank or knife edged to reduce weight.
Never seen or heard of a dyno comparison between polished cranks.
However, I am now selling my b20/vtec before I could ever put it into my civic so I will never know how great she runs.
Re: b20 vtec experts??????? Balance and polish crank???????????? (Sears_Teg)
I got screwed over for a tranny so my funds are running low. $1400 to be exact. If I sell off my motor and mods I will have just enough for an itr swap. You can read up about my loss using the search function. I would love to install my motor into my hatch but life is a windy road to go through.
Here is a link to my motor for sale. I lowered the price to $3900 local pick or $200-$300 for shipping depending on where you live. I am negotiable for my extra parts as well. I will have pics up within the next few days.
https://honda-tech.com/zerothread?id=329494
