Prob with timing check, help!!
Old Jan 24, 2003 | 05:33 PM
leadfoot78's Avatar
Default Prob with timing check, help!!
Ok this is the first problem after the swap. I decided to buy a timing gun and check the timing cuz I replaced the timing belt and took off the distributor a few times. Warmed up the car turned it off jumped the connector hooked up the timing light. I go to turn on the car and it starts then the rpms slowly fall and the motor dies. I try to start again it starts but quickly dies again. After disconnecting the damn timing gun the fuel pump wont prime. I left for a few hours came back and everything is fine car started and i drove it around all is good. Then with the gun hooked up the same thing happen again. Anybody know anything about this???? i need help bad.
Old Jan 25, 2003 | 09:48 AM
leadfoot78's Avatar
Default Re: Prob with timing check, help!! (leadfoot78)
Did anyone see that before? The car is running fine now but i can't check timing. Is my battery low or what??
Old Jan 25, 2003 | 10:28 AM
Kamin's Avatar
are you grounding the timing gun?
Old Jan 25, 2003 | 02:38 PM
leadfoot78's Avatar
Default Re: Prob with timing check, help!! (Kamin)
I tried grounding at the battery and at the tranny ground too.
slow-ef
Mar 26, 2009 10:53 AM
nick32
Dec 28, 2005 01:48 PM
NatedoggAZ
14
Apr 13, 2005 09:51 AM
wpgcivic
Jan 16, 2005 06:15 PM
