h22 engine mounts!!??
Old Jan 23, 2003 | 12:01 PM
h22dx's Avatar
Default h22 engine mounts!!??
i know this ? has been asked a dozen times but i need to ask it again. im putting the h22 in my ek, but i dont know what mounts to use. hasport, hcp, place racing?? but heres my main ?, what problems except the 30 mph vibration have u had with ur mount kits? thanks
Old Jan 23, 2003 | 01:00 PM
h22dx's Avatar
Default Re: h22 engine mounts!!?? (h22dx)
with the hasport kit do u need anything else with the mount kit or just the mounts, such as cross member?
Old Jan 23, 2003 | 03:05 PM
paulzy's Avatar
http://www.hasport.com
http://www.hcpengineering.com
http://www.placeracing.com
all the info you need is in these sites
Old Jan 23, 2003 | 04:51 PM
KENLUDE97's Avatar
Default Re: h22 engine mounts!!?? (1320development)
I have not herd a whole lot of good things about Place racing... HCP and HAS are your best roughts! I used the HCP and they worked well so for
Old Jan 23, 2003 | 05:43 PM
h22dx's Avatar
Default Re: h22 engine mounts!!?? (KENLUDE97)
kenlude97, ur engine bay looks badass!! just thought id tell u
Old Jan 23, 2003 | 05:47 PM
h22dx's Avatar
if i went with the hcp, do i need the cross member support, should i get the street or race setup? i might drag the car every once and a while.????????????????//
Old Jan 23, 2003 | 05:58 PM
VTECVillain's Avatar
Get the street compound no matter what kit you buy. They are stiffer than OEM rubber mounts and perfect for weekend drag racing. The race compound is too stiff for everday driving and will rattle your *** numb.
[Modified by VTECVillain, 9:58 PM 1/23/2003]
Old Jan 23, 2003 | 06:06 PM
Newman's Avatar
New User
On the EK Civics, if you're using the stock driver's side gel-filled mount, then yes it's very advisable to use the front crossbar. Otherwise, I've seen people's motors tear their stock framerail bracket right off of the frame because of the amount of power their using from the motor. Now, if you get a full urethane driver's side mount (Place Racing has one, HCP is coming out with there's in a couple of weeks), then it feels just like an EG Civic with 3 mounts - I test drove an EK hatch with the HCP prototype mount and there's no movement. The front crossbar is there for extra stability.
Old Jan 23, 2003 | 06:33 PM
FleXingMyEK's Avatar
Default Re: h22 engine mounts!!?? (Newman)
I have place racing mounts and they seem fine to me, just when i start the car it rattles a bit.
compdog694u
Dec 12, 2006 12:28 PM
yaya
Sep 8, 2006 10:40 AM
TEALmobile
Jan 30, 2003 01:03 PM
civicsitek GanGsTa
Oct 9, 2002 11:44 AM
