B16a Vaccum Lines
B16a Vaccum Lines
Ok i need to know how to run my vaccum lines correctly so my B16a will run right in my 88 hatch.I heard that you have to T one of the lines off because in Japan the SiR comes with a pressure regulator solenoid cut-off and a purge cut-off on the MAP sensor.I've also heard that you can use the MAP off of a 90-91 integtra but i dont know how true this is.I just want a definative answer to my problem so i decided to ask the best............................thanx!!!!!!!!!!
Asahi
05-17-2003 03:37 PM
