B18C5 swap... do I need knock sensor for OBD1 P28?
Whats up, I am swapping a B18C5 swap into my '95 coupe. I have the p28 ecu chipped, and am planning on using the wiring from my original engine (d16Z6) Anyways, all plugs line up and everything, (except injector plugs and distributor plug, which have all been soldered from the old harness) but I have noticed some people say that the knock sensor from the old harness needs to be on the motor... is this true? Why would I need it with obd1 ecu?
Re: B18C5 swap... do I need knock sensor for OBD1 P28? (MEANB18)
im thinking about doing the same swap as you and was wondering what year your motor was? how are you going to wire up the distributor and the injectors? if you have any additional information on how to wire the motor up i would really appreciate it if you shared...thanks
New User
Re: B18C5 swap... do I need knock sensor for OBD1 P28? (6pucker)
Re: B18C5 swap... do I need knock sensor for OBD1 P28? (TimoneX)
Anyways, all plugs line up and everything, (except injector plugs and distributor plug, which have all been soldered from the old harness)?
you can replug the distributor, rewire the injectors or use your old ones (both flow the same)
P28 doesn't need a knock sensor as it was never designed to run one.
Re: B18C5 swap... do I need knock sensor for OBD1 P28? (eg6ajk)
running the b18c5 with the obd2 harness and a chipped p28 without ks will it give me a check engine light?
My motor is a 2000. I wired the injectors by using the injectors off the obd2 harness. I cut them with a little extra slack just incase. I cut the obd1 sohc injector plugs and tossed them. Then I just soldered the wires on, but remember the colors of the wires on the plugs, they match for each injector (obd1-obd2). As far as the distributor, the obd1 plug has two seperate plugs, whereas the obd2 has only one. you'll have to look up in the honda manual what the extra wire is, I believe it is another ground or possibly just another wire that can be taped off. Hope that helps, email me if you have any other questions.
if the b18c5 is jdm can i still use the jdm harness? will it plug up to the shock tower plugs in the engine bay? and you said all the other plugs on the harnesse will plub up except for the injector wires and the distributor plug? is there certain manuals you would suggest? your information has helped alot...thanks
JDM or not it should still work if I remember right. When you get to the injector wires, take the first injector on the passenger side from the old harness, and match the wires with the new plug wires... they are the exact same colors except for the third plug from the drivers side... and there is only one wire that is different, you should still know which is which. Very easy, just solder the new wires on the old! As far as a wiring book, I would suggest the Honda repair manual for both engines.
so if i use the stock harness from the civic(92-95) every little plug except for the injector and distributor should plug up? you have any information on the distributor wiring? thanks again
just a little FYI, there is no JDM b18c5. JDM ITR motors just say B18 on them. not that this makes a difference...
[Modified by dreamer, 11:52 PM 1/25/2003]
Re: B18C5 swap... do I need knock sensor for OBD1 P28? (dreamer)
uhh you forgot the C JDM Integra Type R motors are labled "B18C"
Same as the JDM Sir-G!!
If you use your stock Civic harness you'll need to cut the plug off the OBD1 distributor and then solder them to the new OBD1 distributor... It's fairly straight foreward... You can do so by just matching up the colors of wires... If you need anything else lemme know.. Peace
Another option is to use a pre-2000 JDM ITR P73 ECU. This ECU is basically just an OBDI ECU with OBDII plugs. With the exception of the knock sensor, no additional sensors need to be wired up. I will be using the P73 with my B18C5 swap since it is cheaper than reprogramming a 1992-1995 ECU (The P73 came with the motor but a chipped P28 would be something I have to buy. And I can rewire for free).
As for the distributer, all 1992+ distributers are electronically compatible with ANY 1992+ ECU.
[Modified by StorminMatt, 5:30 AM 1/29/2003]
Re: B18C5 swap... do I need knock sensor for OBD1 P28? (StorminMatt)
if i cant figure out a way of wiring in the itr distributor can i just use a 0bd1 distributor from a 94-95 gsr?
Yea that's the other option, I really doubt that you would have too much trouble with that wiring tho... it's not complicated at all, like i said just match the colors up... Peace
Re: B18C5 swap... do I need knock sensor for OBD1 P28? (Kataku2K3)
so all the wires just color match? are there any wires that is not used? (92-95 civic distributor wire harness to whatever year itr distributor)
thanks
thanks
Well I forgot one thing to add I guess, do I need to have the crank positioning sensor? The obd1 harness does NOT have this, so I wouldn't THINK I need it if it doesn't go to my ecu anyways.
ABout the distributor plug, The obd1 harness will have TWO plugs instead of the obd2 single plug. (I think it's the same on the obd1 integra harness) The bottom plug, or the plug that has only two wires, you cut and tape the BLUE wire, this is a tach wire that is not needed. The black with yellow stripe wire, match up with the same wire on the obd2 plug. keep going down the line, the colors should match. If not, look on the side going directly into the distributor and match the colors that way... HAHA kind of hard to explain! Hope this helps...
hey guys I got a jdm obd1B18c w/ cut harness. I was wondering if I can use my obd1 sohc vtec harness for this motor?
Re: B18C5 swap... do I need knock sensor for OBD1 P28? (SupaFly_Honda)
If your dropping it into a 92-95 Civic or 94-2001 Teg yup... You'll have to rewire the plugs just as I was sayin abouve^^ but it's not hard at all... If you want it to look really nice you'll have to extend and shorten some wires... Again not all that much work... I would pull the entire loom off, extend, shorten, and move what you need to the rewrap it all back up... Good Luck
