ecu trouble
Old Jan 23, 2003 | 04:48 PM
Trust No One's Avatar
Default ecu trouble
Alright my car is 96 hx with a b16a. the car runs smooth until its time for vtec to kick in. When vtec kicks in its like its not even there? Also when the car sits at idle it all of a sudden almost cuts off it does this about every 30sec.. The motor has passed compresion test and the idle is perfect I just dont know anymore. I am thinking the ecu is bad it is 95 delsol.
thanks for your help.
Old Jan 23, 2003 | 05:22 PM
VTECVillain's Avatar
Default Re: ecu trouble (Trust No One)
Is your check engine light on or does it come on when this happens? If so you need to see what codes it's throwing and go from there.
Old Jan 24, 2003 | 11:36 AM
Default Re: ecu trouble (VTECVillain)
there is no check engine light. man I have been trying to figure this out for sometime now.
Old Jan 24, 2003 | 02:26 PM
sushiracer22's Avatar
i hope youre not using your stock hx ecu harness.....hx's dont have vtec so theres no wiring for any of the vtec stuff...did this happen all of the sudden?? or only after you did the swap??
Old Jan 25, 2003 | 06:18 AM
Default Re: ecu trouble (sushiracer22)
Yes Iam using my stock hx harness.But the car used to hit vtec hard? But the harness wouldnt effect the fucked up idle.
Old Jan 25, 2003 | 08:38 AM
usually the messed up idle would reflect a vacuum leak of some sort....you might want to check the lines to the evap solenoid and anything related to the evap system.
Old Jan 25, 2003 | 08:50 AM
Thanks alot for your input i will try that and see if it works, still my car is slow because of the vtec?
Sparcofreak
Apr 9, 2015 03:13 PM
bmxmacdaddy
Feb 28, 2009 01:49 PM
94ludeh22
Nov 16, 2005 07:14 AM
B20_SI_CRX
Jun 3, 2005 09:03 PM
wiber1
Mar 24, 2002 04:21 PM
