lsvtec or crvtec?
Old Jan 15, 2003 | 10:38 PM
DelSol808's Avatar
Default lsvtec or crvtec?
pros? cons? which one would you prefer? and why?
Old Jan 16, 2003 | 12:36 AM
function83's Avatar
Default Re: lsvtec or crvtec? (DelSol808)
b20vtec would be fast but wouldn't last long due to thin cylinder walls.
lsvtec should be sturdy and fast if built right.
https://honda-tech.com/zerosearch
click that link and search lsvtec.
Old Jan 16, 2003 | 07:49 AM
Specail Ed's Avatar
Default Re: lsvtec or crvtec? (djhatch)
H22!
Old Jan 16, 2003 | 08:30 AM
SiBirdie's Avatar
b20 can be just as reliable as a lsvtec. IF both are built properly and normal maintance they will last. Also dont smote on them 24/7.
Old Jan 16, 2003 | 01:32 PM
Jeff C's Avatar
Do you have big plans for the motor or are you just gonna bolt it together and roll with it? If you have plans for sleeving it in the near future, then I say go lsvtec. If you just want to bolt it together and have fun, then I say crvtec.
If you have a 5 or 6g civic or 94+teg, then I am with Special Ed...H22.
Old Apr 21, 2003 | 06:48 PM
rota426's Avatar
Default Re: lsvtec or crvtec? (Jeff C)
You do know that the cylinders in the h22 are pivoted toward the driver, where in the b-series, they point away from the driver. This causes balance issues, and makes the h22 even harder to mount. save your time and go crvtec.
Nate
Old Apr 21, 2003 | 06:50 PM
IS3Fifty's Avatar
Default Re: lsvtec or crvtec? (styler7)
id say ls... its a little more race breed.
Old Apr 21, 2003 | 11:11 PM
orange.honda's Avatar
Default Re: lsvtec or crvtec? (purek9hybrid)
run a mini me. its cheap and they are reliable and powerfull. (whenn done and tuned correctly)
Old Apr 22, 2003 | 01:34 AM
D16Z6racing's Avatar
Default Re: lsvtec or crvtec? (orange.honda)
LS/VTEC
Parts avaliblity.
Old Apr 22, 2003 | 01:56 AM
torr's Avatar
Default Re: lsvtec or crvtec? (D16Z6racing)
b20 and ls are the same, b20 is just bored an extra .2 i'd say find the cheapest block, ls or b20 and get it sleeved to 84
Old Apr 22, 2003 | 06:05 AM
rota426's Avatar
Default Re: lsvtec or crvtec? (torr)
no sleeve, too expensive - just get a b20 with aftermkt rods/pistons/rngs/etc and leave the head...you will be set.
Nate
Old Apr 22, 2003 | 08:42 AM
HRILSVTEC's Avatar
If your not going to build the motor up go with the B20vtec.
97spooncivic
Feb 8, 2010 04:44 PM
doodooheadfart
Jan 29, 2006 12:38 PM
91DroppedHatch
Dec 12, 2004 03:05 PM
DOMKID
Mar 8, 2004 09:12 PM
Honda-Hooligan
Feb 15, 2004 12:22 PM
