b16a2(sirII).....94 civic ex (92-95 civic)
i have some questions about this swap...mainly obd differences ( i know mine is obdI...sirII is obdII right? ). So i have read to change injectors, dist., and i think ecu (chipped)...to get the b16a2 running right, i'm just making sure, is this correct? What about a obdII > obdI conversion harness, will it work as well?
ok...the rear motor mount also needs to be from a 94+ gs-r, now do most places that sell swaps sell this mount with the motor (i.e. Hmotorsonline)? Basically do they sell the swap to fit the car? or is a swap sold as is....meaning buying extra parts to get it to work...?
I think thats about it.....about half is questions and the other half confirmation....
I've already searched through 30+ pages.....Thanks in advance.
Re: b16a2(sirII).....94 civic ex (5thgen)
no the SiR II is OBD1 it was found in 92-95 civic hatches (the SiRII) in japan.
the b16a2 is 99+ and its obdII. the SiRII is just called a b16a.
i got my swap from steve (hondamotors) and everything came with it.
Re: b16a2(sirII).....94 civic ex (Kamin)
ahhhh....so an sirII is plug and play with the exception of the knock sensor wires....maaaybe vtec wire(s)?
sweet...thanks, thats what i was lookin for
Re: b16a2(sirII).....94 civic ex (nsxmatt)
ya man your swap is plug and play
but if your running a chipped p28 from lowcashracing ... you won't need the knock sensor to be hooked up...
Re: b16a2(sirII).....94 civic ex (respectblades)
is the sirII b16 a plug n play in my obdII EK?? besides the vtec wire. sorry for posting in your thread dude, i had the same question but on different year.
Re: b16a2(sirII).....94 civic ex (SuperMan19)
you are better off trying to find a REAL b16a2 and doing it that way
you need to change injectors, distributor and other various things i dont remember.
not to mention converting to obdI
no
no
odds are they are using b16a2's wich are DIFFRENT than SIR II's
you can use an SIR 2 if you convert to OBDI and im 99% sure you dont need to change the dist. and injectors then.
to kamin: how much did you spend total for the complete swap? And your saying you didn't buy anything extra JUST the complete sir II swap from hondamotors?
Re: b16a2(sirII).....94 civic ex (ricemaster (r))
and no i didnt need anything extra for the swap. everything worked fine that came with it
when he says complete swap, he means, complete swap.
[Modified by Kamin, 11:46 PM 1/25/2003]
CiViCShella
07-10-2012 02:04 PM
