Helping a friend with his motor swap and i have a few questions
We are putting a 95 LS motor into a 93 ex coupe. We also have a 91 LS that's crashed, he wants to use the tranny from the 91. Is this possible and if so what's modification is needed to make it fit? Can we also use the shift linkage from the 91 integra?
Thanks in advance for the help.
Re: Helping a friend with his motor swap and i have a few questions (smokeee)
The tranny would work with some gay *** modifications and I WOULD NOT waste my time doing it... first of all the 91 tranny is gonna be cable, his coupe is hydro... As for the tranny bolting up to the 95 LS motor that would work... You would need a hydro to cable conversion which I have done before but don't like... If not done perfectly right you'll go through slave cylinders right and left... You'll also need a custom mount for that side... If you did that then you would probably just have to buy a whole Hasport kit or something like that... The shift linkage should work fine but i would just sell the cable tranny and look for a hydro.. That's just my opinion tho... Peace
Re: Helping a friend with his motor swap and i have a few questions (Kataku2K3)
I'd kept the hydro tranny since it's less time consuming and less headaches
JDMJohn413
06-25-2009 12:25 PM
c-y-nickel
10-31-2003 02:51 PM
