HELP NEEDED on b20z/vtec project
Old Jan 22, 2003 | 05:48 PM
dragonz04's Avatar
Default HELP NEEDED on b20z/vtec project
eg6 civic coupe
MODS
-00 b16a2 head w/ skunk 2 dual valve springs + skunk 2 titanium retainers
(head is HIGHLY MILLED)
not yet ported or polished
type r cams and gears
type r distributor
skunk 2 intake manifold
-01 b20z block (sleeved)
crower rods
FOR SALE:
b20z head + other stuff soon available
QUESTION: what pistons should I use???? I know i'm gonna be buying
j.e. pistons but 11:1 compresion or should it be 13:1 due to the head milling?
but i also know that 11:1 is for street use and it's okay to use 91 pump gas,but 13:1 is for race gas. U.S. has 91 octane gas and I heard that is not good for the motor.
I don't want the motor detonating on me. Plz help out,
email me at: dragonz04@hotmail.com
Old Jan 22, 2003 | 08:00 PM
RenoRacing's Avatar
Default Re: HELP NEEDED on b20z/vtec project (dragonz04)
if you're hardcore you'll go for the 13:1's but if you want it to be streetable and cheaper on gas go with the 11:1's it'll still rip ***!!!
Old Jan 22, 2003 | 10:49 PM
dragonz04's Avatar
I will go for the 13:1, but what kind of gas should i be pumpin?
and should i get those "octane booster" ****, does that actually work?
thanx
Old Jan 22, 2003 | 11:36 PM
insane900rr's Avatar
If you go 13:1 you won't be able to run it on the street with pump gas. 12.5:1 is about the highest that you can go safely on pump gas. The higher the compression ratio that you go the more heat that you will be grenerating, and you don't want to cause detination were your burning a hole in the piston. That would ruin your day.
Old Jan 23, 2003 | 11:02 AM
dragonz04's Avatar
Default Re: HELP NEEDED on b20z/vtec project (insane900rr)
Thanx a lot, so I should go w/ the 12:5:1
what else should I do, to prevent engine detonation?
b16nonoy
May 17, 2006 06:14 PM
all motor b20b
Aug 19, 2004 07:32 PM
xEGxB18Cx
May 25, 2003 12:30 PM
Pinhead
Jun 24, 2002 10:25 PM
