code 22!!
Old Jan 18, 2003 | 11:12 PM
shonnys92si's Avatar
Default code 22!!
i finally wired up my knock sensor and IAB. now that code 23 went away, code 22 is showing now. i know its the vtec , but how do i check it. need help guys please reply. thanx
Old Jan 19, 2003 | 02:47 AM
tinkerbell's Avatar
Default Re: code 22!! (shonnys92si)
is that vtec pressure switch or vtec solenoid? (i cant rememebr)
either/or, check the wiring, then check the sensor/solenoid...
t..
Old Jan 19, 2003 | 04:09 PM
VTECVillain's Avatar
Default Re: code 22!! (tinkerbell)
VTEC Oil Pressure Switch - defective circuit or unplugged / defective oil pressure switch
Old Jan 19, 2003 | 08:55 PM
Default Re: code 22!! (VTECVillain)
what should i do to check and to verify what exactly is the problem.
Old Jan 19, 2003 | 08:58 PM
tinkerbell's Avatar
make sure the thing sticking out of the VTEC solenoid with the green plug (ie the VTEC oil pressure switch) is undamaged and plugged in.
check that the wires from the green plug run to the right pinouts on the ECU. (?)
if the wiring checks out OK, substiture teh VTEC oil pressure switch with a known good one (ie one off a friends car...)
t..
[Modified by tinkerbell, 3:59 PM 1/20/2003]
Old Jan 20, 2003 | 11:45 PM
cool ill try that 2morrow
cioli
12
Feb 26, 2006 08:31 AM
drudy
Aug 26, 2005 12:20 PM
punkassazn
Oct 1, 2004 12:13 PM
ViXoN Hatch94
May 7, 2004 02:10 PM
EKweezy
Jun 25, 2003 02:35 PM
