what little things to buy when swapping?
I just found out you need to use new snap rings on the end of the axles that go into the tranny and you need to use new cotter pins on the castle nuts. What extra little things like these need to be replaced when swapping a b18 into an EK? I want to be prepared as much as possible when i do the swap.
List:
cotter pins
snap rings
timing belt
water pump
spark plugs and wires
rotor
i think new bolts for the engine and tranny mounts. i recall it saying replace those in my helms manual for my civic.
axle nuts
electrical connections
anything else?
[Modified by deviant1, 4:48 PM 1/24/2003]
List:
cotter pins
snap rings
timing belt
water pump
rotor
axle nuts
anything else?
Re: what little things to buy when swapping? (deviant1)
that was a great question to ask,, i hope you get many replys back! u mite need nuts and **** just case u strip em
Re: what little things to buy when swapping? (wm5holla)
dont forget food and beer!! pins to connect wires to the ecu and wires, connectors or a soldering gun.
[Modified by jmm96gsr, 3:41 PM 1/24/2003]
Distributor cap, brakleen (LOTS), feeler gauges, anti-seize, extra vacuum line, pcv valve, oil filter. Hell if it were me I would change all belts as well including timing. Do whatever is going to be a bitch once the motor is in the car.
new_climber
03-22-2008 03:21 AM
pennies_hatchie
08-28-2002 12:07 PM
