Help b16a2 JDM Harness not compatible!!!
Is there any way to fix the harness that comes on the jdm b16? Its very different??? I do have a usdm harness that i put on but im wondering if the harness they gave me can be altered to make it fit?
Re: Help b16a2 JDM Harness not compatible!!! (Civic_driver)
dont bother. just clip off the connectors you need to add to your existing harness so you can run the necessary wires. It will save you many headaches.
Re: Help b16a2 JDM Harness not compatible!!! (erniecars)
I ran into that problem too. Just use your USDM harness, clip the other plugs you need, and run the wires for vtec/knock sensor/o2 sensor
Re: Help b16a2 JDM Harness not compatible!!! (Gray EG on Jack Stands)
or just get a civic ex engine harness and just add knock sensor or just get a chipped p28. You will just have to extend the O2 harness a little down into the harness, this can be done by cutting the harness open then pulling th O2 plug towards the center of the harness by the tps and map sensor plugs and jsut tape it back up a little and your good to go.
