Motor swap
Motor swap
Ok guys I have a 88 hatchback it current has (well had) a d15b7 well something happened it crapped out so I bought another motor supposed to b the same exact well it's a d15b2 is there anything I would have to change distributor Ecu wiring harness etc. Please let me know asap
Re: Motor swap
I know that the d15b2 runs on only 2 injectors and the d15b7 runs on 4 so you'll need a d15b2 injector wire harness, and the d15b2 trans needs a different trans mount than the b7.
Re: Motor swap
Ok well I was reading that u can use a dpfi harness and move some wires around to use mpfi I do believe that's what some1 done to mine I wonder if I could reverse it and run dpfi
DOHCintegra91
09-24-2006 08:29 AM
Beau Gotti
02-12-2006 02:11 PM
95excoupe
11-14-2004 10:03 PM
