1320 Ramhorn header. Who has dyno results?
Hello H-T.
I am debating on getting this for my stock ITR but want to find more information on it. I have searched but I didn't find any solid proof that this thing is good or trash.
Has anyone tested this header on the dyno? If so, what were the results?
TIA
TIA
Re: 1320 Ramhorn header. Who has dyno results?
What header do you currently have?
I haven't seen anything on it yet either. It's a copy of a good design, but whether or not it was done correctly is a different story. The PLM Toda rep and RMF Narrow headers have proven to be the best all around headers on 1.8's. I say that from experience and research.
Just curious, is the said ITR motor the one making 180/156 in your signature? That's an *** ton of TQ out of a 87mm crank 1.8...
I have the 1320 toda rep header. the head flange seems like its warped but when u torque it down there are no leaks so I dont care. besides that it's a solid header especially for the money im quite happy with it
Ask yourself this. Are you going for looks or quality/power/functionality. I put my money on a toda or rmf narrow any day. Dyno tested results.
@93egSLEEPER
I currently have a skunk2 alpha header.
Last time my ITR was on the dyno it made 179/122 with RMF replica on stock p73 ecu.
No my sig was a different setup from several years ago.
I have thought about the Toda rep as well. I was just curious about the ramhorn header because it looks wild.
I also was wondering if compatible for A/C on a EG Hatchback?? An if so any Pictures Guys.
As far as a/c clearance its looks ok. Ive never had it in my eg. Pic you can judge for yourself. Biggest Complaint i had was that its all crammed over in the air intake side. So i was sucking in hot air. May have to ajust your radiator releif hose as well and have a thin fan.
Here's an old setup of mine with plm ramhorn. I only did one dyno with it. Gs-r with s2 tuner 1 cams ctr pistons made 205/143tq. That setup was extremely jacked up internally so those numbers are really just numbers.
good numbers man
TitanMotorsports.com
335
09-03-2008 04:56 PM
Del Soouulll
15
04-11-2007 10:23 PM
B18Redline
01-16-2003 09:41 PM
