Running rich, long term negative effects?
Old 12-12-2017, 10:19 AM
jdmark1's Avatar
Default Running rich, long term negative effects?
I did a B18B swap a couple months ago. Everything 100% stock from the ECU to the headers. I re did its entire intake side. Cleaned out IM, new gaskets, o-rings, vacuum lines, etc. Upon starting it up, the fast idle behaved normally as it should, but the idle never dropped below 1100 even with the adjustment screw on the TB down all the way. It's a steady idle, not fluctuating so iv been driving it just fine. I took a look at it recently and noticed a few of the I'M mounting nuts were loose so I figured the vacuum leak was coming from there. I fixed that issue, and the idle went down a little bit. I know it's running rich from looking at plugs and a slight smell, and I think it's because of another vacuum leak. The ECU trying to correct for the additional intake air and running a lil too much fuel. Anyway, my question is are there any long term effects of running slightly rich? Any possible damage to the internals or sensors? Anything of that nature.
jdmark1 is online now
Old 12-17-2017, 12:38 PM
motoxxxman's Avatar
Default Re: Running rich, long term negative effects?
a little rich, no, nothing bad will happen. a decent amount rich and it will start thinning the oil out and washing oil off the cyl walls.
get a smoke test done to find any remaining vacuum leaks.
motoxxxman is offline
brian0918
07-15-2015 06:34 PM
UCLA.lion
General Discussion and Debate
02-16-2007 02:11 AM
Jowee
05-15-2005 01:11 PM
Teg4e
10-13-2002 10:08 AM
White98LS
07-06-2002 04:03 PM
Quick Reply: Running rich, long term negative effects?
  • Ask a Question
Question Title:
Description:
