H22 swap issues
Old Sep 27, 2017 | 04:25 PM
Cd5lyf's Avatar
Icon4 H22 swap issues
I recently swapped into my 97 accord an h22a4 i am running the f22b1 wiring harness with some h22a4 conections tranfered over, i went today and got a obd2a to obd1 jumper harness from speed factory and also a p28 chipped with a h22 basemap because "that was what i needed" so i was told, the motor ran perfect before i pulled it out of the prelude all cylinders compression tested at 202-207 psi, the motor runs alright at an idle and i can rev it up by very slightly pushing on the throttle, anymore and it bogs/stalls at any rpm, i was running the f22b1 ecu before and it runs exactly the same totally stumped on where to go next there is also no CEL
Old Sep 27, 2017 | 09:49 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: H22 swap issues
It sounds like your TPS and MAP sensor plugs are swapped... try switching them and see what happens.
Old Sep 28, 2017 | 07:51 AM
Cd5lyf's Avatar
Alright, tried that and the problem just got worst and I had a little more trouble starting it
Old Sep 28, 2017 | 09:17 AM
Cd5lyf's Avatar
so there is what seems to be a crank case vent box under the intake manifol, vacume lines go to it, i did not have a plug in for this on the f22b1 harness could that cause problems like this?
Old Sep 28, 2017 | 02:15 PM
Cd5lyf's Avatar
Update: running code 1 and code 22 on obd1 p13, no codes on obd2 f22b1 ecu
mills7x
Sep 12, 2011 03:49 PM
teefunk01
Northeast (Sales)
Oct 21, 2008 04:40 PM
dschwantz
May 18, 2008 02:50 PM
righteyeblind
Mar 31, 2008 08:05 PM
hondacg5
Jan 15, 2008 10:25 AM
