swapping a 94 b18c1 into 96 integra ls help!!!
from my understanding the 94 is an obd1 and my ls is an obd2. what do i need to interchange between the both of them in order for the swap to be as smooth as possible???
Re: swapping a 94 b18c1 into 96 integra ls help!!!
Did you already read the "Sticky" thread on how to do exactly what you are asking ???
https://honda-tech.com/forums/hybrid...A-%2A-1972711/
Technical Hero
If you're not concerned about emissions
-OBD1 P72 with ECU adapter harness OBD2A-OBD1
-either reuse your harness and use a subharness for VTEC, knock and IAB. Also distributor adapter harness OBD2A-OBD1. "Unclip" your injectors connectors and plug right in or swap injectors over from your old motor.
or
use the B18C1 harness and wire VTEC, knock and IAB from the shock tower to ECU.
check this thread I made as well
https://honda-tech.com/forums/honda-...-vtec-2987229/
or
4thgenlude
13
10-24-2006 10:46 AM
