Axle Won't Fully Slide In
CRX with B18a1 OBD1 engine swap. I can't get the driver side axle to slide in. I bought a 93 Integra axle. It fits partially but won't go fully in. Tried taking the C clip off, same thing. Other one went in without an issue and I've tried for a while it just won't go. Could I have the wrong intermediate shaft? Only thing I can think, not sure if a later int shaft would be close enough to fit but not slide in fully though. Let me know what you think, thanks
Re: Axle Won't Fully Slide In
Make sure that your driver side axle has splines going all the way down the shaft. I bought a "driver side" axle and was given a passenger side axle. The passenger side's splines only go half way to form the sealing surface for the axle seal.
OmgDelSol
09-10-2014 02:16 PM
integrainside
Transmission & Drivetrain
10-03-2013 05:21 PM
