HONDA LX E.G SWAP 2 A B18B1
Hey guys & girls!
I purchased a 1995 Honda lx E.G. The stock motor non VTECH is about to go!
with that being said i bought a B18B1 motor. I need to build it first before i do the swap!
(ANY ADVICE?) IM trying to figure out if i should go VTECH - ALL MOTOR - OR BOOST???
Also i need to change the clutch, what is the best clutch ???????? (MY FIRST PROJECT CAR)
O.G. triple O.G.
Re: HONDA LX E.G SWAP 2 A B18B1
Get either OBD1 or OBD2 B18B1 complete swap (engine harness, both axles, shift linkage, motor mounts, sensors, etc.). If it is an OBD2, pick up an OBD1 P75 and you should be good to go.
Best durable clutch -- ACT Street/Strip HD.
Don't forget the usual maintenance parts: timing belt, accessory belts, water pump, belt tensioner, rear and front main seals, valve cover gasket, spark plug gaskets, spark plugs......
blown302
11-06-2010 07:03 AM
PotatoePAPA
32
01-20-2004 12:27 PM
datsun510dude
02-13-2003 05:58 PM
