2-bolt post doesn't line up with 2-bolt mount
Old Oct 4, 2017 | 06:46 PM
Curlybandit's Avatar
Default 2-bolt post doesn't line up with 2-bolt mount
Hey everyone.
I'm having an issue with my swap. For reference, I'm getting an OBD1 JDM GSR b18c motor swapped into my '93 del Sol Si. It had a d16z6 and I was using Innovative Mounts engine mounts with 75A poly.
I contacted Innovative Mounts to confirm if their driver's side 2-bolt mount will work with the b18. Their website indicates that the mount is for both D and B motors. They replied that it would.
Unfortunately, the offset bolts and the holes of the mount don't line up. I've attached a pic.
Has anyone seen this before? Any suggestions on how to resolve this?
Thanks!
Old Oct 4, 2017 | 09:21 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: 2-bolt post doesn't line up with 2-bolt mount
Your problem isn't the mounts... it is the engine bracket bolted to the side of the block. The 2-bolt bracket that you have pictured above is from a '90-93 Integra... NOT a '99-00 Civic Si. It is likely that the B18C engine that you have last resided in the engine bay of a 4G ('88-91) Civic/CRX. You will need to purchase the '99-00 Civic Si 2-bolt bracket to use with the Innovative mount that you have pictured above. Just because it is a "two bolt" bracket doesn't mean it is the CORRECT "two bolt" bracket.
Good Luck.
Old Oct 4, 2017 | 09:23 PM
JRCivic1's Avatar
10 Year Member
Community Builder
If you cannot find a used one, the factory part number for the bracket that you need is 11910-P30-000.
Old Oct 5, 2017 | 04:45 AM
Fabtastic info!
The part has been ordered.
Thanks!!
Old Oct 7, 2017 | 06:28 PM
JRCivic1's Avatar
10 Year Member
Community Builder
You are most welcome.
EG_SINZ
Mar 8, 2012 05:10 AM
Sammy Po
Jan 10, 2010 09:54 PM
colbynorwood
May 21, 2009 05:26 PM
jadsi420
Aug 11, 2005 07:16 AM
txhatch
Sep 9, 2003 12:17 PM
