need engine help asap
Old Jul 3, 2007 | 06:58 PM
vtec_powah's Avatar
New User
Default need engine help asap
will a head and block from a 94 gsr work in my 96 integra gsr
reason i ask is i blew the engine in my car, and picked up a 94 head and block, but noticed that the oil pumps are not the same, now im wondering if anything else is different
Old Jul 4, 2007 | 07:38 AM
turbociviccoupe's Avatar
Default Re: need engine help asap (vtec_powah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec_powah &raquo;</TD></TR><TR><TD CLASS="quote">will a head and block from a 94 gsr work in my 96 integra gsr
reason i ask is i blew the engine in my car, and picked up a 94 head and block, but noticed that the oil pumps are not the same, now im wondering if anything else is different</TD></TR></TABLE>
the head will work
Old Jul 4, 2007 | 08:43 AM
egsleepercivic's Avatar
get a obd2 oil pump, the block and head are the same as the one you blew up
Old Jul 4, 2007 | 01:00 PM
vtec_powah's Avatar
New User
so if i put an oil pump from a 96gsr, it will work with no problems
Old Jul 4, 2007 | 01:08 PM
it should the obd2 has a sensor that the obd1 doesn't, you also want to use your OBD2 dizzy as well, the only difference is going to be a sensor or 2. physically the block and head are the same. sorry i don't know alot about obd2
gl
B_Swapped93
Feb 9, 2013 10:03 AM
matt c
Nov 9, 2006 03:00 PM
RICE POLICE SIP
Apr 5, 2006 09:07 PM
standinghollow
Oct 14, 2005 12:53 PM
cowboybebop
Jun 14, 2005 05:31 PM
