What sensor is this? (GSR IM)
* B A N N E D *
doing my swap.....my dx harness didnt have this plug and im not sure what it is and also where do these hoses hook up too?
(obviously the one thats not plug that I'm asking about...)
(Does this hose connect to the IACV?)
the plug is the IAT (intake air temp)
the hose is the evap purge feed line. the evap purge valve is just above the IAT in the first pic. one side goes into the intake, the other the charcoal canister. (the black can next to the heater valve)
MiG-21 superfan
Re: (Pishpeng)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pishpeng »</TD></TR><TR><TD CLASS="quote">What are the color wires that plug into the IAT? Red/yellow and what is the other one if it is only 2 wires??</TD></TR></TABLE>
i'd just use the intake tube mounted IAT that came stock in your car...leave the IM one alone.
* B A N N E D *
Re: (builthatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by builthatch »</TD></TR><TR><TD CLASS="quote">
i'd just use the intake tube mounted IAT that came stock in your car...leave the IM one alone.</TD></TR></TABLE>
im a lil confused a pic would help please
MiG-21 superfan
Re: (Pishpeng)
hmm, i dont have pics that would help, but...
on you car, stock, there is a two wire sensor that is black with a gray point on it. it is inserted into the intake tube; should not be hard to find since there is only one sensor on/in the intake tube.
so, what im saying is, just use that sensor and keep it in the intake tube instead of worrying about hooking up the one that you asked about on the intake manifold.
also, while that line on the canister does indeed go to the nipple atop your throttle body, it actually can be left off with no harm to anything cept maybe a emissions inspection.
jhmcrx
12-25-2004 05:28 PM
