Compare my numbers to yours: B18a with PCT pistons, out of the hole measurement?
I calculated that with the PCT pistons in a B18a block, the piston would be sticking up out of the hole 0.0153543 inches. Is this correct?
I also did the same for a B16a block with PCT pistons. I calculated that the piston would be sticking up out of the hole 0.0070866 inches. Is this correct?
Thanks!
Thanks!
