[Help] - Eg h22 alternator problem
Hi
Everytime I start my car with the alternator plugged in, it would fired up for about 2-3 seconds then stall. When I unplug the alternator, it starts up fine. This problem only happens on cold starts
Has anyone had a similar problem to this on HT or know how to fix this problem
thanks
thanks
Re: [Help] - Eg h22 alternator problem (aus_newbie)
hmmm seems like the alternator is some how draining ur power. Your battery is able to start the car just fine, its seems there may be something wrong with the alternator draining power giving ur car no power, i would just throw in a new alternator or change the diodes
Re: (JasonST)
I'm thinking it might be the wiring as well. This is because the eg alternator
plug(Aus spec) has 3 wires coming out were as the h22 has 4.
Did you have similar problem wiring up the alternator?
thanks
thanks
